Snapped map sensor
Car  Ph1 T
Trying to get it out I snapped it on the bit where it pushes into the inlet. Now the only other one I have is a 2 bar one could I fit that? Or will I need a standard one?
Dan
I believe the 2Bar should work just fine chap. How did you manage to break it though, Ham fists again?
Did you get the bit you snapped off? If the one you snapped is a 2bar then it will be fine if its different it won't as its been mapped.
Mick I was just wiggling it about to try and get it out for painting inlet and just snapped on the kneck...
No it was standard the one that broke so can't I put my 2 bar in?
This happened to me once too, the little bit flew inside the plenum - I nearly shat myself!
Got a spare pretty quickly on here though :)
Got one sorted but Won't be sent till tommorow so have it Tuesday hopefully. I've managed to silicons where the sensor snapped back together and it's gone in as a temp solution till new one comes
