take the weight of the engine/gearbox using a jack etc. undo the big nut in the centre of the mount and the two either side,then lift the old rubber part out and drop the new one in.
no the bolt is attatched to the lower part of the mount the bit that is bolted to the box via 3 bolts. it comes up through the upper part of the mount you just drop it on and put the nut you took off back on so it looks like this
Will have a nose tomorow u might get a text tomorrow lol U know u say take the rubber part off ? Is that the but what you can see when i first took my battery out ?
