Sounds and Clio
Car  lots!! Inc 95 1.4 clio
Hi Been offered a 12" Sub, Amp & CD Changer cheap.......problem now is how to squeeze it in Clio.......also any advice re. wiring kits....are the cheap ones on Fleabay any good. Cheers Mike
with regards to wiring kits anything made by autoleads is generally decent quality, this will do the trick halfords will try to charge you around £30 for that piece of kit.
CD Changer - have you thought of velcro'ing it underneath your passenger seat? if not mount it vertically in a corner of your boot.
Amp - I personally mounted my amp to the back of the rear seat, this guide may help you out.
Sub - Only place for a sub really is in your boot, not alot more to say about that tbh
Go for a good wiring kit like Streetwires or maybe Autoleads
The install depends what ICE it is & what it looks like too if you wanted to make a "feature" of it for shows instead of hiding it all for the subtle effect.
So many ideas out there for simple installs to maximise space if that's what you need?
