spacers + coilovers = worn arches!?
  Italian 3.2 V6
just having a think...
when fitting 20-25mm spacers and coilovers, -60mm (ish) drop... will the tyres not rub against the arches f**king the paint work when doing general driving, going over bump and around corners!? seing as there is about 1mm gap between them!?????????
some1 please enlighten me on this !?
cheers, piers.
  Mk2 Clio 1.6
yes!!
ive only got a mk2 1.6...and ive got 15mm spacers and standard springs and my wheels bounce off the arch going over bumpy roads etc..
im guessing yours would be even worse.
  Italian 3.2 V6
dub/euro type of theme.. just generaly wonderd how ppl went about this dilema..?
Struggler
  Ph1 track 172
unless you have streched tyres,
your going to hit something,
roll the archers,
or get smaller spacers.
  Italian 3.2 V6
roll the aches!? whats that!?
whats the maximum before this problem happens!? 10mm?
Greeny.
  440i + 182
negative camber ftw :)
I have 15mm spacers on my 15's to make the track abit wider and they hit now and again under hard cornering, I can live with it though.
  "Navy" N17 TWO
^ You finally got your spacers sorted? :)
Which ones did you end up with mate and do you have studs?
Greeny.
  440i + 182
15mm delta mics hubcentric, had to get some 42mm nuts as the ones that come with them are god awful! I rounded one when first taking the wheels off.
  Italian 3.2 V6
no no going to do it euro style, just always wondered lol, wouldnt mindmaking wheels a little more flush witharces mind.. 10mm maby.. got 5mm ones atm..
