spark plug change
Car  clio 480t ,172, clio mk2
just done the spark plugs on the 172 and it now seems as if its firing on 3 cyclinders i took the inlet back off all the leads are on correctly and in the correct order dodgy lead ? any ideas cheers guys
ive just checked all the leads for continuity and resistance and there fine duff plug maybe
i just took it down the road and its awful to drive
If your looking at the engine gb end cylinder 1234 the leads have 1234 and on the coil from bottom rigth 1next along 2 then top left 3 then top rigth 4
You're always meant to check them, its very easy for then to take a knock in transit, on the shelf etc. Pop the old plugs in and see what it's like.
no as they all looked clean after a small run and it was internitant not arching a spark all the time must be a dogey tip or something
