spark plug coil??
  Clio
Hi does anyone have the part number and/or know how much one is from renault? My car sint under warrenty so cant get them all replaced, need to do a trial and error me thinks??
cheers, Mike
  CB600FS
Mikey to find out which coil(s) is down manually, remove the engine cover, remove the 4 bolts holding the coils in, but leave the coils there. Start it up, and in turn, lift each coil, if you can remove it all the way without it making any difference to the engine - thats the duff one.
You should also be able to hearing it 'sparking' when its just lifted from the top of the plug. Theres a few other ways of doing it, e.g injector plug/clip computer misfire rate. Inspect them for cracks aswell, arching against the head.
  Clio
cheers dude thats great thanks ^^ Tom.
Ben. where do you recommend I buy one can you get new ones on ebay then?
  RB 182
I bought mine from Renault because I needed to get my car back running. You will need to change them all as the others will fail shortly otherwise.
