Spax Coilover springs
Mr R.
  A special one.
Does anyone know if Spax do a shorter spring for there coilovers?
I have my fronts on the lowest setting but would like to get them a bit lower.
  Clio 172 phase 1
They don't I've been on with them the past few days to see what they can do basically its what it is they can make a custom damper for trax use but no shorter springs I spoke about the psx kit with them and they couldn't do any more .... They've hooked me up an Rsx kit now at a really good price through my works ... There customer service is good email or ring them and they might be able to come up with something
Mr R.
  A special one.
Cheers dude but i have the RSX kit, i may even end up selling them for something else
  Ph2 172
[pikey] Have you tried taking the helper springs out? [/pikey]
I found that the fronts didn't go very low either, I ran mine at the lowest possible and I didn't want 'lowzz Yo!' In the first place.
Did you fit the spacer below the suspension top mount? Only about 20mm long iirc but I left it out after reading on here that it was unnecessary I had no issues without the spacer fitted.
Mr R.
  A special one.
I was thinking about taking the helper springs out tbh, but thought id chuck up a post to see if other springs where available before i did this.
I don't remember seeing a spacer tbh mate, i have the black alloy bit that holds the top of the spring then the top mounts.
Now i have spaced my front wheels out it stands out that it needs to be sitting a bit lower.
If not then i might sell them and get the FK ones as the adjustment threads go alot lower down the body of the shock.
  Ph2 172
How are yours standing up to the British weather? I had mine in Oz where rust isn't an issue, I'll be looking to buy another set when I get another Clio.
