Special Wheel Bolts
They do make slightly wonky bolts to fit them - I've seen them before. You have to use them if you want to make aftermarket wheels fit a punto as next to no-one makes 4x98
I dont understand how these bolts work. I wouldnt use them. Although the offset of the clios wheels will be about right the centre bore wouldnt match but would fit.
Need new spiggots as well apparently, found a place near me that sells them, £2.50 per bolt
