Speed Sensor through ABS??
Not sure if this is in the right section or not.
I've learned that Clios that don't have the Speed Sensor on the gearbox bell housing use the ABS Sensor. Is that correct? And if so, which one? My diagnostics keeps coming up "Speed Sensor fault" with no code or anything. Also there is quite violent hesitation which is only getting worse, as if the car ostensibly tryin to stall. Plus my rev counter and temp gauge die sometimes.
Someone please help. I've already had about 900 - 1000 spent on the car :(
