This thread is here for our members of the product test panel to submit reviews, pictures and discuss our Spirit Carnauba Wax.
An overview:
Our Spirit wax has been carefully designed to give optical clarity and a crisp gloss to all metallic and pearlescent paint finishes. While many waxes and sealants can actually mute pearl and metallic paints, Spirit’s visual clarity, crispness, and gloss have the opposite effect. Pearls and metallics truly sparkle. Spirit is one of the harder waxes in our range, its firm consistency allows the wax to be spread in super-thin coats, minimising waste, and making buff-off really easy.
Putting it into action:
Preparation is key…
As with any of our carnauba waxes you need a clean surface for Spirit to bond too. Our pre-wax cleanser, Rejuvenate is designed to work in-conjunction with our hard waxes to insure any last contaminates are removed before application. The glazing oils in Rejuvenate will then leave behind a clean surface ready to apply the wax.
Start by adding a pea-sized amount of Rejuvenate onto a microfibre applicator.
Next, using straight linear motions work the Rejuvenate into the surface.
Once it has cured, take a fresh microfibre cloth and buff off any residue left behind, be sure to work one panel at a time.
Application of Spirit:
Once you have insured the paintwork is correctly prepared, it’s time to grab a Waxmate or our new Handi Puck and wax spot pad! Place the applicator inside the wax pot and twist a quarter-turn to prime the pad.
Spirit can be applied to the whole vehicle first, then buffed off straight after. Some people prefer to apply the wax to two panels at a time - buffing these off before moving on to another two panels. Let us know what you guys prefer…
Spirit should be applied with small, overlapping circular strokes, light pressure, and in a consistent pattern to obtain full coverage of the paint. The goal when using this wax is to apply the product as thinly and evenly as possible - a little bit goes a long way! If the applicator feels like it is starting to run dry across the surface, or coverage becomes uneven, return the applicator to the container using another quarter-turn of the pad to re-prime the foam.re
Removal:
When removing Spirit make sure to use a clean microfibre towel. Here we are using our Primo Plush cloth which has a deep fluffy pile both sides, making it perfect for that final buff down.
The finishing shots:
Once Spirit has been fully removed and buffed away, it will leave a crisp glossy finish that offers between 3 and 4 months durability on a daily driven vehicle.
We look forward to seeing your experiences with Spirit and the result it gives you…
More info on how to use it and reviews can be found here on our website here http://shop.autofinesse.co.uk/spirit-200ml
An overview:
Preparation is key…
Removal:
