spoiler torx screw size
J273
Car  RB 182
Fitting a cup spoiler when i get it hopefully this week...Just had a look at the standard jobby but am unsure on what sizw the torx screws are to get the thing off with...Also ive heard i may need a washer hose will this need to be from reno? or can i get it from say halfords?
Jamie
Just fitted it ...didnt need to do any mods to it at all straight swap....ive found though that the rear washer jet must be slightly leaking around the joint as if i keep my finder on the rear wash wipe it seeps under the spoiler....I dont really fancy taking it off again and i dont use the rear wash....Do you know if the stick connectors are waterproof or not? ...as i dont wanna short the electrics.
Here's an idea, odd one but here we go.
This is how it works, you get your torx bits out and go out tot he car and try them in the hole till you find one that fits, would have taken all of about 2 minutes rather than waiting over an hour and a half
helps if you have the bits.....got a torx 20 now though;)
Any ideas guys ?
I doubt it'll be waterproof as it's just a push-fit connector. Personally I would remove the spoiler and sort the leak :)
