Sportlines scraping
koi
Scraping from back right with people in the back. Anyone else have this?
Shocks have just been replaced all around earlier in the year so should be fine.
Would old springs cause this? Had a look and they look in one piece but rear right looked a bit rusty
Yeah Renault ones, never usually have people I'm the back so first I've noticed it.
Odd. Easiest way, don't give people lifts, lol. Does seem odd. It can only really be the shocks or springs.
I had cooksports springs (lower then sportlines) and new cup dampeners (rears are all same) and had 3 mates in car with me (rugby players) and my car was fine, if that helps. Shouldn't be rubbing if they are tell your mates to lose weight or catch bus haha
Is it on the outside (you'll see marks on the outer edge of your tyre) or the inside (you'll see marks on your arch liners)?
Standard wheels?
See where it's rubbing first.
I'm in the same boat, my fronts are catching. running eibach with std shocks. about to swap to new cup shocks all round in hope of a quick fix.. probably ready for a refresh after 89k mind..
I post with my findings
Depends where its rubbing on the front, I'm guessing its probably at full lock?
Bumper bracket probably needs bending out of the way, the extra caster wishbones don't help this issue.
Wheels are Oz so sit a bit further out than standard.
Turns out it was catching on the rear arch liner, need to screw it back on and check it again.
