Spraying advice for PH1 Silver Centre Console and Gearknob
  PH1 172 Sport
Ive decided that I want my gearknob and the silver part of the centre console to match my door pulls which are in Iceberg Silver.
As the console has that rubbery/plastic coat on it and its in fairly good nick I was just going to etch into it with a medium grade sand paper instead of stripping it right back to plastic. Should this be ok?
With the gearknob do I have to go back to the bare metal or can I just etch into the surface again and spray over the top?
Not sure what you mean about the dash, but you'll get away with just giving the gearknob a good rough up and then etching onto that without going back to bare metal.
  PH1 172 Sport
Ok cheers. The PH1 has a a silver centre console which is layered with the same stuff that they use on the door pulls. With the door pulls I had to go back to the plastic as they had melted but the centre console is in pretty good condition so I didn't really want to do that if I could get away with it!
  Storm Grey 200
You want to be taking it right back to plastic, otherwise the paint looks a bit s**t. You do know to take the centre part out you have to take the whole lower dash out... I did it in my project thread
  PH1 172 Sport
Ah right well ive tried it without going back to the plastic. It looks ok apart from the iceberg silver ive got is a really bad match.
I got it from Auto-Paint which I heard were supossed to be good but its just too dark.
