Progress has been slow, not helped with the bad weather and waiting on some parts.
A catch tank, PMS breather plate, fuel pressure regulator housing and new 4bar pressure regulator and a KTec fuel rail turned up
With a break in the weather yesterday and some help from my brother to fit the injectors to the fuel rail I mounted the breather plate and the fuel rail
Yes it is a bad photo as it started to rain as I was just finishing. I only plugged the injectors in so the pins were not open to the elements. I went out this morning and moved the wires to come though the bodies at the back behind the rail. The cable conduit has turned up si I can now redo the covering on the injector wires and get that all positioned niceley. However having problems with the TPS so I can't wire that in so need to wait until KTec get back to me with a solution. Turns out they have made a bit of an oversight with the Ph1 set up as their new TPS is not compatible with the Ph1 loom. I hope they are getting me a wiring diagram of their TPS so I can wire it into my loom (but will put a connector in it somehow so I can remove it) as
@NorthloopCup sent me the diagram for the loom, I just don't know what the sensor is.
The heat shield material turned up so I need to get a pair of snips and work out how to fix it to the car. Probably try and use the existing moutning points but I know it is going to be a right faff. Need to work out where to put the catch tank - with suggestions next to the coolant expansion tank so will have to do that after the heat shield goes on.
Made a diagram of how my fuel supply set up is going to be along with plumping in the fuel tank breather that went into the carbon cannister that I have now removed.
This has made me work out what I need to order. Basically some 8mm fuel hose and jubilee clips. But waiting for KTec to come back to me about the TPS so I can order the right wiring stuff for that at the same time, although thinking about it I know what I think it shoould be so might just get it now.
Throttle cable and ABS sensor is on the way from AUTODOC, no idea if the throttle cable is any good seeing as I can't get hold of a genuine item any more. Although Renparts are selling a LHD one, but what is the difference between a LHD and RHD?! I also hope the ABS sensor works as that would be 4 I have tried and I don't really want to be going down fitting a Cup brake set up so I can remove the ABS.
I think I have hit a point with this where I am just now with the fiddly jobs that take time and there are no quick wins with bolting stuff on anymore. Not going to have a chance to work on it next weekend but the following weekend I am home on my own so will get the parts lined up to get cracking.
