spring rotating
Car  Dodgy one
Think i've got a boloxed top mount bearing, Just to confirm if i have,
I'd get a bit of knocking while driving and I'd hear the spring rotating in the spring pan wouldnt I? It also Creaks and hasnt done before
It is now on coilovers, but it has only just started doing it and they've been on a few weeks now i think
My coilies were the same, got told it's normal with them. 172Ben had a similar problem and Tweeks said it was normal iirc.
It cant be surely, I can her the spring basically twang when turning the wheel, as far as i can remember back its always the strut that rotated and the springs were fixed in the pans
So could I, but coilovers are different as they aren't in the same kind of locators that standard struts are.
Yes, so far. The plan is to change them for some solid ones in future although i'd hoped they'd have lasted a few more months yet, Its only ones side doing it :(
Fitted correctly? nice and tight? could be top bearing, just coincidentally going when you upgraded.
Yes, doublechecked too as i was doubting myself, Just seems to have happened these last few days the knocking, and now been able to heat the spring twang.
Guessing this is going to cost me nigh on £100 in total to get them tracked back up after the new bearings gone on too, Just when i wanted to get the new forza lol
Changed the topmount now, quiet as a mouse :approve: guess the rubber had, had it too as the knockings gone :touch wood
