Springs? Relocation Pipe?
  Clio Dynamique 16V
Right, bear with me here. :D
Iam looking at buying a set of Eibach pro springs. I have a 2003 1.2 16V. Will these actually lower the car or just make an improvement to the handling??
Secondly, with the k-tec relocation pipe, will it not fit as i have air conditioning??
  M2 Competition
They will lower the car, but only a lil bit mate.
I dont think it will fit, aircon is in the way of where the pipe runs, just behind the grille.
  Clio Dynamique 16V
Cheers mate. Yeah thats what i thought. Would there be any way round the problem with the air con unit behind the grill?
  172 cup'd extreme
dont buy the k-tec kit it makes the 1.2 16v's inlet tract longer than its already is you will loose response and power. better off with a sheilded filter ie bmc, viper, venom
Martin_172
k-tec relocation pipe is toss anyway, lost mine power and torque, was shuddering when pulling away because of loss of torque and heat soak.
its nice if you want noise just not for power.
as for suspension, apex it. if your just changing springs go for -40mm or if your going full kit go for -60mm kit, you could always go for coilovers but i was told the apex kit is more planted than coilovers (someone told me fred said that, cant remember who tho?)
