Springs
"These Apex Sport Springs (150-4051) fit the Renault Clio Mk2 2.0 RS 172/182 models (99-05)"
  • "lowering:40 mm"
aslong as your car is a 172 or 182 and was built between the years of 1999 or 2005 they will 100% fit.
and also they lower 40mm alround.
ideally with lowering springs you should use a shortened strut to avoid accelerated wear on the damper. How much life is left in the dampers is anybodys best guess. The damper may potentially last longer than you have the car, but it will wear faster..
