Standard Brakes
280mm front discs - get from anywhere -got a set yesterday for £50 (allparts)
238mm rear discs - get from renaault £95 +vat with bearing and abs ring fitted (got mine this morning )
Pads you can get anywhere and are between £20 - £30 for each set
What do you need to know? The front brakes are Lucas calipers same from a Laguna, the discs are 280mm, internally vented, the pads will be the Renault ones unless theyve been changed. The rears are Bendix/Bosch calipers same used on most citroens and Peugeots. The rears are 238mm.
Your mad but they are cheaper than Buying OE I believe.... GSF and the likes stock them at decent prices
Edit - :( Slow Fingers FTL :(
