Steering Column Adjustment Broken
After a bit of guidance. Clio mk3 steering column adjustment had broken, wouldn’t lock in either up/down or forward/backward motion. Fixed the up/down part but still won’t lock forward/backwards. Does this all look right? Also this spring was loose under dash but not sure where it goes... cheers
Did you get anywhere with this issue?
My up and down works but my steering column stuck in the out position and won't go in.
Is that meant to happen?
