i have a complete new suspension + coilovers. my camber is set on -1.
i've done the tracking and now when i drive the steering wheel is slightly to the right when i'm driving straight. when i put the steering wheel in the centre the car is slightly going to the left.
does it pull in the direction of the camber? is your steering wheel straight on a completely flat road? if not you need four wheel alignment. i do at my place, where you from?
Its just I had my Camber + tracking laser aligned once I lowered mine a month or so ago and it still pulls to the right. Not as much as before might I add but it still does.
The Guy just said 'because its lowered you can't adjust the rear'. So it's sitting at -1' of camber at the back and 0.19'L, 0.36' toe at the back. Fronts are -0.02'L+R.
it should pull when on in any directyion when on level ground. either somethings gone eg ball joint, top mounts etc or trackings out. id nip it into a place that does free tracking checks and see what they say
Thats the thing it was 'done'. Will give em a call and see what they say on Monday. I have the printout of the 4 wheel alignment, could upload it and see if you or anybody else see anything that stands out?
PS @xoldog400 Sorry for hijacking your thread but I was going to post something soonish anyway and its the same topic
like i said nip it into another local garage to you, most will have alignment equipment and see what they say, if its out you have something to take back to them. i work in millimetres not degrees so couldnt help too much
