Stereo only playing out of front drivers side speaker. Help!
Car  Red 1.2 Dynamique
The audio from the stereo only playing out of front drivers side speaker. There are two wires dangling behind the stereo that have been cut and aren't attached to anything, one goes right and is white, one goes left and is grey. I'm wondering if they're the problem and if so where and what they connect to?
Many thanks
If there aren't any cut wires or missing pins in the loom at the back of the stereo that those wire would connect to then check the back of the speaker itself. Just pop off the cover on the door and a torx bit will take them out and check connections.
