Hey ive got a 06 clio and have been trying to fit my aftermarket stereo but theres too many wires behind the headunit so sticks out about 3 inches still! is there anywhere / tips on where to put the cables?
Were the cupholder is in the centre console, the top part of that comes out, remove it, stick your hand up and pull the wires down, The headunit will go in easy then.
remove glovebox to do it
remove trim above glovebox,3 screws on top,2 inside and 1 to the left behind the door seal
then you can pull the wires up through the top of the hole where the radio sits
i had the same problem the other day, you just need to try and make sure the wiring block is not lumped at the back of the stereo, theres not a great deal of space
Well thats not really the problem, i can get that up in the gap, its just the rest of the cables! theres loads, ive tried taping them together but thats jus made it harder!:
