still not quite level!
Car  New Kangoo Van!
had a spring kit fitted bout 2 months (apex) ago along with a passanger side new front shock. the passenger side rear still looks about 1/4 inch higher than the drivers! been 2 numerous places and nobody knows its a mystery! :mad:
the car sat level b4 i had the springs fitted!
any bright ones anybody?
My old 1.6 on an apex -40mm kit (springs+dampers) was the same. They're just not the best really, haven't had anything like it with the eibachs i've got on the 172.
i didnt have any problems with my eibach pro's (apart from that they didnt lower the car much) just wanted to go a bit lower
If you just had 1 front shock fitted ..it is probably just natural wear and tear in the non replaced shock that has made it lower...they gradually compress.
Might be an idea to get a new one for the driver side too.
Might also be a silly question but are your tyres inflated the same?..mine was sitting wonky and it was low on air on one side.
d'ya think it'd be an idea 2 replace the other shock on the drivers side or will it settle down in time? suppose its how much time tho!
