STOP/BRAKE light flicker on dash, fluid level fine, breaking solid?!
  Ph1 172
Got the STOP light and brake symbol on the dash flickering alot when driving. My fluid level is perfect...
Ever since I got the tracking sorted, this problem started happening? What could they have done when adjusting the tracking to cause this??
Thanks.
mad in general
  Clio 172 phase 2
I believe that the electrical contacts for the rear light clusters will be at fault here. If you remove them, clean them up and make sure all is fitting well then your problem should disappear.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Unplug the brake fluid resevoir level sensor from the cap and take it for a drive. If the light stops replace the level sensor.
Also check you don't have brake pad wear lines as these catch on the inner arch and do the same.
  SAAB 93 Aero TTiD SS
I have started getting this now but only on long left hand bends.....any ideas?
