stop/handbrake light
Guyss/girls need ur help on this one. Everytime I'm going round a bend or parked on a slope the stop lights n handbrake light come on, my oil levels fine coolants fine and thers 1 next to the coolant which I don't know if its brake or power steering fluid which is topped up too, is there anything else I need to be checking??
santoz
  Clio 182
brake fluid needs topped up!
you need to take the engine cover off to get into the brake fluid reservior as its to the back and left of engine!
cheers lucky i was going to put it in the power steering reservoir! but ill get that topped up as soon as then hopefully the light will stop flickering
it means your brake pads are low...(leading to it indicating low fluid level)...
topping up the fluid will only take your pads right down to the bare minimum...
new pads needed
