strainge noise
Car  missmy257bhp r5/ got evo6
hi my ff 182 has a strainge noise coming from the engine area
engine its self is fine but its like the time my centre box rattled when the inner box came loose (normal clio problem) renault did the center box as normal under warranty is there anything that could rattle up by the engine
i cant explain the sound
but as strange as it sounds it makes the car sound a bit electric
what could it be
any ideas
thanks rich
electric? i think i know what you mean...sounds like a tensioner or pully might be the problem? does it happen at higher revs or just on idle?
it does it throught the revs
bit worryed now
thought it might be a minor loose part vibrating
will get it to renault asap
bit worryed now
at the same point in the revs or all over?
had a sim sounding prob. mine made a electric/buzzing at 2.8K on the revs. any gear/speed or with no gear selected.
could just rev it to 2.8 and it would start buzzing. would be gone my 3k tho.
stopped after about 3 weeks and hav'nt had since
if its buzzing...then dont worry about pulleys etc...if it is a constant noise that increases with pitch as you go faster and then decreases as you go slowly.... then id go for the pulley issue.
yeah its all the time and gets louder as i rev it
its going to renault tomorrow(robbing b******s)
they think its either pulley,alternater,waterpump bearings
anyone know which of these are most com
why do i buy renaults its only done 20000 miles from new and is only a few months out of the warranty :banghead: :cry: :banghead:
renault want to strip it down and charge me loads just to look
they recon it takes about 3 hours just to strip the plastic out to look :banghead:
they said its def a bearing going of some kind
Yep they have to change the aux belt maybe the cambelt if its that tensioneners or pullys which are the problem. there no space in there hence the high labout cost the car bumper comes off, head light off, etc.
sounds like you might have to have the cambelt and aux belt done while they replace pulley/tensioner :-( big £££££
pictures of the car when you get a minute.
