Streaming Audio Using Remote Desktop
Car  BMW e46 320 Ci Sport
Question: Guys can you do this? So you remote onto a desktop and then stream music onto the local machine, say using the remote desktop feature or someother tool? obviously it would require more bandwidth, but if thats no problem?
Anyone any ideas?
RDC allows sounds from the pc your connecting to to be pushed to the pc your on if required. its in the options :)
yeah must be a bandwidth issue then cause that doesn't work for some reason, cheers lads.
Remote Desktop Connection
Click "Options >>>"
Then click 'local resources' Tab
Under 'Remote computer sound' Click the drop down select 'Bring to this computer'
IMO, Remove desktop is the best, I use it all the time to control my car pc from my bedroom.
Edit:Opps, Didn't notice
David said:
thanks adamio i'll check that program out actually
Yeah give it a try
Running it from my PC to work i get almost CD Quality audio, but obviously that all depends on bandwidth.
You can connect to the stream using most audio players (Winamp / Media Player) but if you use the SoftSqueeze player you can skip track aswell.
http://www.orb.com/
you can view webcam too... so if your pc is in ur room and ur at work.. you can see if anyone goes in your room whilst ur out ;)
Pretty quick too... used to do this with my XDA...
