Stripped Mk1 Project
can i use my original driveshafts and hubs etc, dont really want the wide track on front if possible?? maybe even my gearbox or will the power just kill them??
thanks
thanks
The 16v dont have wider track. Only the willy so just use the 16v parts.
The 1.4 shafts prob will fit and be ok. But if you have the 16v bits they are tried and tested.
:D
thanks
:D
oh smart if its not widetrack that helps just need to find a donor now :)
I hope your right Dave!
Are you sure its not a bit wider what with the arches and all? Even if its just slightly longer wishbones. We should look into that!
Quickie from the clio on a diet!
Removed the tar from pass side
Before
After
And then the drivers side
Before
After
Ill get some tar and glue on it tommorrow :)
More strippage to come!!11
Boot
Before
after
Still more to come out from under the seats, but ran out of light :(
Coming on though. How many weeks to Fcs :o
Good job!!! Do love to see people saving weight as well as striving for more power the 2 should go hand in hand IMO. When I stripped the sound deadening out of the valver i weighed it and it weighs around 9kg.
Keep up the good work.
does this actually affect the weight of the car?? and how the hell dya get it out?
Yeah, i think it saves a few Kg, big power with little weight is the idea here.
Using a heat gun and wall paper scraper. :0
9kg thats good going, more weight still to come out.
keep up the good work lads :D
Cheers :star:
how easy is it to get a clio to sub 900kgs?
would be looking at power/weight ratio of around 150bhp+ then with a good 7p lump
Not 100% sure on the weights but im trying to go as lean as i can but retain (most) of the dash.
Need to find a weigh bridge
Few pics from my 5 mins i put into the car today.
More tar out, this time from behind the rear seats.
Before
After
Only tar left is under the seats but that will be out soon, along with a few other changes ;)
Comments welcome as per.
x
^^ looks good mate, just need to clean that mess up an ur sorted.
Dibs on the bonnet when its up for sale!
I started to clean it up but i used all the tar and glue remover in my work :eek:
SO waiting for more to come through.
You have first refusal on the bonnet mate. :star:
