Coil pack then HT Leads the check your Plugs dont need changing and they are sparking all right if its got a lot of black carbon build up it wont spark as well.
The plug leads might be breaking down and causing it to misfire. The coil packs can break down after a while as well.I put Magnecor leads on mine a couple of years ago. I'd change the leads and plugs and see if that cures it.
sounds very similar to the problem i had!
mine turned out to be stem seals and valve guides shot so oil was sitting on 2 pistons which resulted in the injectors being blocked so the fuel was not getting ignighted! mine stank of fuel!
hope its not mate!!!
