Strong Petrol smell, Oil coming out the exhaust & engine a little lumpy..
Car  RS6 C7
On a 172
What could this be?
I don't think it major, Possible coil pack or leads?
Can be slightly tricky to start but does fire up ok. Just runs lumpy and what i think is unburnt fuel is coming out the exhaust.
Burning oil isn't going to be an ignition fault or at least not just a ignition fault.
Compression/leakdown been checked?
The plug leads might be breaking down and causing it to misfire. The coil packs can break down after a while as well.I put Magnecor leads on mine a couple of years ago. I'd change the leads and plugs and see if that cures it.
sounds very similar to the problem i had!
mine turned out to be stem seals and valve guides shot so oil was sitting on 2 pistons which resulted in the injectors being blocked so the fuel was not getting ignighted! mine stank of fuel!
hope its not mate!!!
On a 172
What could this be?
