Ok, sorry ive not updated this in a while!! with christmas, new year and general shocking weather, ive not managed to get out on the car a lot recently!!
however, ive stripped all the interior out of the car (and realised i now need to lower the rear slightly)
all the tar has been removed, un-needed plugs have been cut off and traced back to the dash loom, the rear loom has then been wrapped in tape!
after removing the airbags i feared that the airbag light was going to be an issue with the new MOT regulations!! but i soldiered on and removed the airbag ECU, all the side impact sensors and such, i then started cutting the wiring back until it disappears under the dash, (ill cut it back further when the dash comes out in easter!!) and for some reason, the airbag light turns on and goes off like its supposed too!! result!
i also removed the alarm as it was getting problematic having it with the door open sensors removed etc, it kept going off!!
Ive got my cage back from my nans garage and was hoping it would fit straight in nicely!! However because it was designed for a mk1, the dimensions are ever so slightly different!! (it was too dark to get pics but ill post some up tomorrow) i will most likely have to chop it and have the base plates welded back on at a different angle to fit!!
also ordered side mounts so that i can fit my buckets in the car in the same way as jon_r has! and finally the car is looking like a proper wagon!! :
PICS
mid tar removal! (its such a horrible job!)
ive got all the tar in a bag, ill weigh it when i get a chance to give an idea of how much comes out of the car!!
taped loom
theres so much that can be taken out of the loom, it doesnt weigh much tbh, but makes it look so much tidier when you dont have rogue plugs for the speakers/door sensors/boot light/seats/handbrake etc.....
as the interior stands now!
im leaving everything behing the dash until the easter when im on my next uni break!! ill remove the dash completely and tidy eveything up, and hopefully paint all the inrerior white!!
i also fitted a sunstrip!!
but im allowed one because i dont have any sun visors!! so NER!
