Hammer them out using a punch/screwdriver.Evening all,
As above probably a total dummy question but I’m no mechanic.
I can’t get the strut to hub bolts out, the nuts are off, I can see 1cm of the shaft on the top bolt but can’t get either out. Am I doing something wrong?
Cheers in advance
They'll be under tension from the spring. Try take some of that tension off and it should be easier as it will just drop once you remove the bolts.There spinning freely but they just won’t come out even with the hammer. I’ll have to keep trying. Cheers
just wondering. where they standard bolts or camber adjust ones?It was on stands, I’ve packed up now before my patience expired. I’ll jack it up again tomorrow. Cheers for the advice.
They are standard bolts. I’ve not gone back to do them as I lost interest/forgot. I’ll try again when I put camber bolts in.just wondering. where they standard bolts or camber adjust ones?
