Sub ans Amp
Car  Ibiza 1.9 FR TDi
I'm looking to buy a sub and amp kit with complete wiring kit, looking to spend about £100-£250. Any links or reccomendations?
Don't touch Fli :star:
I'd preffer visiting a local specialist so you have someone to fall back on for installation queries/if any problems occur after buying.
These have quite good reviews for their service ;
www.caraudiodirect.com
www.caraudiosecurity.com
All depends on your budget really but beware of the "cheap brands"
subs arent bad if you dont need youre boot,
get some vibe square 6x9's amp em up with a vibe blackbox amp and there ace, just as loud as a sub, prob get both now for 150ish + bootspace :)
:eek: From a 182 owner you should know to put your performance in the FRONT of the car ;)
Firstly, get a set of good components up front with a good wiring kit, then add a sub & amp in the rear in a subtle install without compromising much bootspace if you need it :)
6x9s are the chav alternative (only just, with huge margins) to a sub if you really need bootspace
he said sub + amp i just mentioned an alternative, obviously better hu and front components is a must for upgrading youre sound system,
for the money he's looking to spend the vibe square 6x9s are quality and would probably match any sub in the price range hes looking at spending, 6x9s are chavish? and subs arent? tut
No just most 6x9's sound shite.
Only but proper sub 6x9, not 3 way crap and they'll need amping and installing on a proper mdf shelf, the standard shelf won't cut it.
