4 x 16mm bolts holding the rack onto the subframe, i leave the rack in, easier IMO
unbolt both ball joints
unbolt dogbone and lower engine mount
drop subframe (remove gearlinkage bar if you're being extra careful)
yep, no idea why you'd want to take the rack out with the frame, sod undo the PAS pipes!
You can fit a normal one but you'll have to drill it for the 4th mount.cheers fellas, just gotta locate one now, are all clio subframes the same?
