Suggest me..
Car  you may know it, clio?
Ipod speakers, around the £80 mark.
Going to uni and think these would be great for general use.
Anyway nothing too fragile and something with more than 20rms we'll say.
i dont know if this is possible in your situation but i have my TV, computer and ipod going through my sound surround amp. if you have some kind of amp, maplins will probably sell you an adapter cable at a much lower cost than a new set of speakers.
only really works if you have some gear already :o
you couldnt justify it though unless you're that women went to bed and won £110 mil.
i love the mothership but 5k !!
Check out the specs on the units
Specifications
  • Engine Room x 2
  • The Power Output: 200W
  • Frequency Response: 20Hz~20KHz±0.5dB
  • Harmonic distortion: less than 2%
  • Signal-to-Noise Ratio: more than 90dB
  • Input impedance: 100Kohm
  • Input Sensitivity: 500mV
  • Output impedance: 0ohm, 4ohm, 8ohm
  • Power Supply: AC100~120V/50~60Hz AC220~240V/50~60Hz
  • Dimensions: (L x W x H) 380X390X185mm
  • Weight: 51kgs
  • Vacuum Tube: KT88x12, 6N8Px4,ECC88x2
Holy crap! and there's two of em :-)
