super unleaded only?!?!
  clio mk2 p1 1.4 16v
i just went to tesco to fill up and ive only had the car a month and realised on the inside of the petrol cap it says super unleaded only?
is this true and will it do harm if i use normal unleaded?
ive put 2 tanks of normal unleaded in now and ive realised on the third... its a 1.4 16v w reg clio etoile if any one needs to know, soooo, is it right?
  clio mk2 p1 1.4 16v
i doint no i can only read super i cant understand bleifreies lmao but actually now i look at it i think its slightly different folds meaning ive been daft and not seen it properly... in my defence its dark :p
thanks
  a thirsty one
yeah but the 182 should be on the higher octane the 1.4 16v is mapped for std unleaded, the super word in the sticker is part of the other language, possibley a country that runs very low ron std unleaded and so the clio needs that countrys super unleaded to vring it upto std levels?
basically stick with the std unleaded fuel thats the correct one for your car.
  Clio 182
not in a 1.4 - When we went to Denmark though, we soon found out that their normal unleaded is actually 93, their "super" is 95. It did not run well on normal Denmark unleaded! you really could tell a massive difference
even in a 182 there isnt much difference 95/98 ron, although I use the high octanes from various garages, unless they don't have it
its best to use higher octane in newer cars, it maybe a bit more expensive but if you use
it reg then you get more miles to the gallon, or have i been watching to much telly!
JMR
  RB 182 Cup
^^^ what he said.;)
In Germany you used to be able [might still be able?] to get 91 RON. The bleifreies [lead-free] super is 95 RON.
  Renault Clio Trophy
When I went travelling to Algeria about 15 years ago, I seem to remember regular was 87 octane and super was 92, both about 12p a litre, both of which our 2.25L Landie ran quite happily on.
Wished we'd taken a diesel as that was 3 PENCE A LITRE!!!
  www.renparts.co.uk
run standard... all the above comments are correct, the octane of standard fuel in this country is correct, its just some countries standard is very low octane so you need super...
