Suspension Help
Car  172 Cup
The Koni's I bought the car with have just about had it so looking to upgrade these to a set of coilovers.
After quite a bit of searching and reading peoples opinions I think I've settled on the Bilstein B14's, my budget was quite limited at around the £600 mark so thought these seemed best given my budget? Or could anyone could recommend a better set for a similar price?
Also While fitting these, is it a good idea to change all the bushes? I'd also like to change the top mounts and fit a strut brace, is it best to fit these whilst fitting the coilovers or is it an easy enough job at a later date?
The car is mainly used for commuting with a spirited drive up over brecon beacons a few times a month
Thanks, Keiran
Looking at
Bilstein b14's, pure motorsports mounts and brace and powerflex bushes
This ok or a bit over kill for road use?
Renault spent a lot of time and money to setup suspension, therefore I'd say all of it's overkill just for the road but I'm old.:cry:
At the end of the day, it's your car and you have to put up with it, your list is ok, it will get various replies stating different thoughts.
Personally I think standard is perfectly good enough, even for track use but everybody's different and spend their money differently.
The shocks on there now are just about gone I think, they used to be firm and handle well but now they're rock solid, to the point the car isn't nice nice to to drive. Would I notice any difference with the solid top mounts and brace if I'm not going on the track?
Only if you're driving like a loon.
