Suspension noise
Car  A4 oil burner !!!
Really annoying chattering / squeaking noise coming predominantly from the front left of my cup. Only noticeable when driving slowly with windows down. Sounds like my shocks squeaking (H&Rs fitted about 9 mths ago) but when i push down on each corner - no noise. Even does it when driving on a fairly smooth road and not just over bumps etc. Anyone had this or any possible prognosis ? Think it could be my suspension arm bushes as had similar noise on my old fiesta :S
sounds odd, but check that the gearbox mount under the battery is tight (especially the bottom nut, under the car)
my H&R's squeek from the back, not even a year old. i think i hit them too much with the jet washer because they started sqeeking after the car was washed..
My thoughts as its only started when i used the car in the heavy rain we had weds
Was fine prior to that
will more than likely be the rubber top mounts in your case mine does it when i have the rear brace fitted
