Suspension Question??
My girlfriend is buying my car off me and we wanted to know the following as the car is a bit too low for her:
The car is currently fitted with V-maxx coilovers. If we raise these, will the camber/caster need doing again?
Or if we fit the standard suspension again, will the camber/caster need redoing??
Thanks!
  TTRS & V50
Caster isn't adjustable !
Will need camber and tracking though.
If you raised it 10-20mm it won't need major adjustment, and its perfectly driveable.
  Golf GTD Mk7
caster won't no. only camber and tracking will have changed. unless you have the adjustable top mounts to allow castor change that is.
You probably wouldn't need to adjust the camber for the only setup unless you had the caster tweeked for the new setup. if that makes sense.lol
Thanks for the replies peeps... My girlfriend has decided that she wants the standard fitting again, so atleast we know it will need taking for tracking etc done!
Thanks!
