TDC fitting guide wires
  172
Hi i got a new TDC Sensor to fit and was trying fit it with mechanic but we werent sure what wires connected which way as the colour scheme is different on the old ones to the new one. And didnt wanna get it wrong and break/damage anything.
Anyone any ideas? its a 172 2001 ph1
DrR
  VW Golf GTD
I put mine on the wrong way due to old wires fading to the same colour, wouldn't start so swapped then fired up first time
  1998 BMW e46 323i
does it have to be soldered? I just bought a new sensor and loom from the stealers... 53 feckin notes.
  Megane dci 130
It comes with heat shrink with solder inside. Also if you folow the pin numbers on the conector, you cant go wrong.
  1998 BMW e46 323i
cheers for that. I didn't have a heat gun thing so just used crimps and duck tape. Worked well.
