TDC Sensor Ph1 Clio
Car  172 Ph1
Having classic starting problems, what's the part number for the "new" TDC sensor, although i'm presuming I probably can't even get hold of the old style one now?
As far as i can see its a case of airbox out, fiddle, unbolt, new one needs soldering in because the loom has changed, but that's basically it? Shall i just contact a dealer for parts, or is there anywhere else cheaper that would bring the same end result?
I've seen circa £5 TDC sensors that claim to fit and work, obvs not genuine, but it makes sense to buy genuine right?
Yep, looking around £60 as i thought straight from Renault, with the "new" loom (what is new about it, it uses the same existing cables, they just changed the connector shape!?!
Anyway, spotted this with 2 days to go on ebay, £20 seems worth a punt, it the blue plug, and has loom, so seems legit, and what can really go wrong with it, as second hand parts go, this should be fiiiiiine, right... Right!? :D
