Also the RGB is off the f**king scale boys.
You wont get g-sync on HDMI. Gotta be display port. You'll max out at 60Hz on HDMI.Yes. Changed to hdmi now though and working ok. Would I benefit much from using display port instead?
Also, I was wondering why my 2TB sata m.2 SSD wasn’t showing up anywhere. After googling/YouTubing and remote help from a mate, the issue is with the m.2 slots on the board (did think it needed initialising in disk management, but it was nowhere to be seen, same in bios).
Only 1 slot supports both nvme and sata m.2, whilst the other only supports nvme. I must have them in the wrong way about (hopefully).
Yes. But Liam has a 1080Ti and a monitor with HDMI 2.0.My LG B9 will do 4k at 120hz, in HDR with G-sync. Just need a 30 series card and a G-sync compatible HDMI2.1 display.
Everything currently default aside from K&M. Haven’t downloaded Corsair/coolermaster rgb software yet.I think we need a video. I bet it's like a rave.
Vid doesnt work for meEverything currently default aside from K&M. Haven’t downloaded Corsair/coolermaster rgb software yet.
Same. I had to watch it in EdgeVid doesnt work for me![]()
You didn’t miss much lol.
So how do I bring across my progress on warzone to PC? I made a blizzard account and it’s given me a generic name/account.
Ok thanks. I had linked the account I was just confused as the new generic blizzard name was showing, until I realised that’s just the blizzard account, not cod, lol. So once I load up tomorrow all should hopefully be there on warzone.
Looking forward to seeing my k/d fall off a cliff for the next couple of months... 😂
Hope so!you’ll be surprised! I went from PS4 on a 50” TV to mouse and keyboard on my pc on a 24” monitor and instantly got better. I find it a lot easier to control the recoil with a mouse.
Don’t think so. None that I can seedoes Nvidia experience have OC and fan settings?
Yeah they're all PWM, I can control them fine with other software ive tried just the Gigabyte one is a bit shite.Make sure your fans are PWM firstly. If they ain't PWM you won't be controlling anything.
As for how to control them? I have mine set in the bios. I have an Asus motherboard and it's called QFan control. I can set curves, set spin up delays and change what temp sensor to use as a measurement.
@bozothenutter you'd have been better waiting until tomorrow to see AMDs new 6800XT reviews before biting the bullet. It's already out there that the new Ryzen CPUs have overtaken Intel's equivalents in terms.of single.core performance. If you are still.within the 2 week return window I strongly suggest you at least return the 10900 CPU.
This cpu seems to idle quite hot. Fluctuates from 40-53. Thought I’d maybe done something wrong, fucked up the paste etc but according to Reddit thermal paste barely makes a difference to these, they just tend to run hot 🤷🏼♂️
Also I thought I could alter fan speed on iCue, turns out you need a separate control box for that. So I’ll have to see if I can do it in bios as they are a bit loud.
Have you installed the software for your AIO to check speeds and adjust fans?
I'm unsure how it works on Cooler Masters but some require the fan header to be set to 12V in the bios for the pump to run correctly.
I have the same cooler and on my mobo I have a pump header, could just use the CPU fan plug. You can't control pump speed on these so they just run flat out.
Mine is like 40 idle (3700x) or something stupid but doesn't really get above 65 when gaming.
Fan speeds I used the mobo software as that's the easiest way.
As rojer said tbhHave you installed the software for your AIO to check speeds and adjust fans?
i actually watched that yesterday. The case/mobo reset bridge? I was looking for where it slots on the board but couldn’t find it!@Moonshot although this has never worked for me, you might have better luck. The cooler has a passthrough to the motherboard so you can control the RGB with the mobo software, if you can get it to work then it saves you another crappy third party program to download as the CM stuff isn't the best and it will be in sync with any mobo RGB you might have. With my MSI board you are supposed to be able to control almost all RGB from their software, but doesn't end up working like that.
If you search on YouTube for Cooler Master RGB and look at the gear seekers videos he explains it quite well.
