Think I have found the fault
I have had a problem with dodgy idling where it bounces upand down from 400 to 900rpm
few things have been changed but still very intermittent.
Was having a poke round the engine bay of the 2001 1.2 16v engine and noticed that the black metal box behind the engine itself was loose as hell, ECU i take it?
Well after looking even closer noticed that the wiring going into one of the sides of it was rubbing againts the metal, to a point where you can acctually see the metal in the wire.
Rekon thats causing dodgy idling? also how would i safely take it out so i can rap some elecy tape around the bare wires?
cheers guys.
yep, common as dog shyte see it loads.
i tend to pull the metal cover off and leave it off to prevent it happening again.
same fault here buddy just pulled mine of was loose to find the bear wires seems to have sorted it
good luck
