Throttle/Accelerator problem
My mate is having a problem with his Clio.
He's having problems with the throttle. He'll be driving along and then all of a sudden the accelerator pedal will stop working, and the car will just sit idling at 500 revs without touching the pedal, and he'll get no response from pushing the pedal, and this sqiggly light comes on the dash (I can't remember what this one means?!):
If he turns on and off the problem is still there, so he has to wait a while before trying again.
Its a Mk2 Ph2 1.2 8v. Would I be right in thinking its possibly the throttle body needs cleaning (I'm no expert!?)
Fly-By-Wire not cable throttle I assume ?
If so, replace it with a known working one... see if that solves the problem. The actuator/solonoid/electrical gubbins are probably borked.
Assuming its the same as a 172, its got one multiwire plug on it and 3 10mm bolts, takes about 2 mins tops
order of likelyhood
Throttle body needs cleaning/replacing
Coilpack fault.
(eleventy billion other things)
throttle pedal.
Plug it in, the light is on for a reason, it will tell you a fault code. Guessing will do you as much good as scratching you bum hole and sniffing it
lool. Okay, cheers!
I can plug in my RStuner to read the code, but the chance of me understanding what the code is actually telling me are quite low tbh lol!
How easy is it to clean the throttle body on mk2 ph2 1.2 8v's?
Right.
Today whipped the throttle body off, cleaned it with carb cleaner, was nice and shiny.
Felt smoother to drive then about ten mins up the road did it again. Now found out it does still drive, but won't go above like 30mph.
Tried pluggin in my RStuner, thinking you didn't need a license to just read fault codes, but wouldn't let me connect, just kept saying VIN unrecognised.
Next most likely coilpack I guess.
Is the coilpacks on the 1.2 8v with the leads aswell or are they separate pencil coils? I remember on my 1.2 16v they were one unit.
