Hi guys , recently I've fitted sportlines onto my car using standard shock s with no problem s , after 2 days or so I fitted camber bolts and set them up 1.5 degrees straight after fitting camber bolts I got this thudding / knocking sound from the right side of the car when cornering hard and going over hard bumPs , left side seems fine and handles corners brilliantly but the right feels like the tyres treading on something repeatedly thud thud thud when I corner hard , sounds bad and does affect the handling abit , I've checked everything for play cv joints are fine , balljoints fine , could it be strut mounts they wernt too bad but I might be wrong and running out of ideas any help and past experience would be appreciated Cheers
