Timing belt
Car  98 Clio RXE 1.6
Looks like my timing belt has broken due to a seized water pump. I think it broke when I was trying to start the car. What is a decent quote for having this repaired? Its a 1.4 1996 clio. So far I have one quote at 300 quid!
Well thats a quote assuming no damage to the engine. The cars value is probably only 300 so looks like it could be time to take it to the scrappy
Thanks for the reply though
I'd expect you to need a set of valves, headgasket set, cambelt kit, water pump, coolant, oil, filters, plugs, and a few other small items. £700 roughly including labour if it's a K7J engine, and there's no piston damage. There WILL be bent valves, what they're suggesting to you is trying a new cambelt to see if it runs, which is a waste of time.
Would there be bent valves if it broke when the engine wasnt even running? (yup I really have no idea what im talking about)
Its unlikely to break when it isn't running as the belt would have to be seriously deteriorated to just snap under tension when stationary? If that did happen then you should be OK as the bottom end wont have been rotating and pistons wont have smashed valves but as I say highly unlikely. Also spinning it over on the starter in that state will have bent some valves. Wouldnt it be cheaper to source a new engine from ebay or someone on here?
Well what I believe happened was:
Water was used instead of coolant
Water froze
I attempted to start car, water pump couldnt turn
Water pump pulley stripped timing belt
I'd say thats 100% had it mate. It may have knackered the block too from it getting frozen.
