Tools needed to fit new RS front discs/pads?
MON
  titty cup'd 182
I couldn't find a Guide/how to on the site, so the question I'd like to know is what tools do I need to fit new front discs and pads to the 182.
I have a caliper wind back tool and have done a fair few disc and pad changes on other cars, so mechanically I know what i'm doing.
If someone knows what size socket/spanners I will need for the carrier & caliper bolts and bleed nipple I would be most grateful to make sure they are nothing unusual and that I have the correct size tools before starting the job. Also if a disc retaining screw is evident, is it most likely to be a crosshead?
Thanks in advance.
Marc.
  Astra van,Mk1 nova
bolts that hold the caliper to the hub are 18mm iirc bleed nipple should be 8mm i think, pads just pop out and the disks are held in place by those torques screw/ bolt, i dont have a clue what size they are, hope this help and im not wrong:D
I think your spot on Eck ;)
I definetely had Torx Screws holding on my standard discs on.
This was when i changed them for Brembo Max Discs and EBC Green Stuff Pads.
Suprisenly they came out and didn't round off head wise or break/snap :)
  Astra van,Mk1 nova
brownie points for me :approve:
Alastair.
  986'S 172ph1+182FF
remove 13mm bolt on caliper, only the bottom one as u can just slide the caliper off when the 13mm is off.
remove pads
squeeze bak caliper piston with a large set of grips (make sure brake fluid cap is off and remember 2 press bak the piston slowly)
remove 2x 18mm bolts from the brake pad carrier
remove disc screw with a torques 40 bit, (idealy u want an impact hammer to)
wak the disc off with a hammer
clean hub and pad carrier with a wire brush
fuk im board
  Astra van,Mk1 nova
remove pads
fuk im board
You've just shown me up! so im going to bed :rasp:
remove pads
fuk im board
And copper slip as well if you wish on the hub faces etc. ;)
Alastair.
  986'S 172ph1+182FF
remove pads
fuk im board
alright u cheeky monkey:rasp:
MON
  titty cup'd 182
Thanks for the info guys, much appreciated. So no unusual tools then, as mentoned I have a caliper wind back tool and also an impact driver, so it shouldn't cause any problems.
I've not done a renault before and not had the wheel off, so hadn't looked at the caliper in detail.
