going to attempt to fit this myself over the weekend, what tools are required? just a standard socket set? i presume its best to put the rear up on axle stands? is it an easy job?
Can you not just put the rear on axle stands and then use a jack to lift the beam up to the right height? I only ask as I don't have ramps, nor a supply of bricks.
iv got ramps, so is it easier to remove bolts etc if the wheels are on a set of ramps rather than hanging if u used axle stands? struts were replaced a few months ago so bolts should be ok to remove.
