Top mount re-assembly
Been a while since I took them apart and my pictures aren't all that clear... So is this how the first nut is supposed to sit? Then modified washer/spacer on top of that, then top 'hat' then 21mm nut. Please confirm if you know!
Camera Roll-232 by -Jon_KTM-
Camera Roll-231 by -Jon_KTM-
Ive just put mine back on std shocks amd my top mounts had some slight play in them the gap wasnt as big as that though. There is a guy on here who sells a spacer to take that out but with the weight of the car on them there isnt any play at all.
Got the new top mounts and spacer. Assume I don't need the original bolt and washer like yours?
Going to replace my top mounts soon. I bought the spacer washer from Dan Mad to stop my current ones making a racket, does this mean I can skip buying the £8 per side spacer for the new style topmounts, or do I need them anyway?
koi I think if you have the modified nut/washer from Renault then you don't need the original nut and spacer
bright I didn't buy £8 spacers and used the M.A.D washer. Seems fine and they've been on for 3k miles and about 4 months+
