tourque settings please
  C63 AMG, F430 & 172
mrk1 172
i need...
the 4 rear stub axel bolts
rear calliper bolts (the two 17mm ones that hold the pad in)
rear shock bolt (into axel)
wish bone bolts 1st, and second
the two ball joint to wishbone bolts
outer ARB bolt
subframe brace bar bolts
front calliper mounting bolts (to hub)
castle nut for the driveshafts
Geatbox mount values
top mount values
dog bone values
lower gearbox mount values
track rod end to hub
front and rear subframe bolts
thanks
  F4R'd ITB'd '92 cup racer
getting your moneys worth out of the torque wrench there! lol
i dont even own a torque wrench! its bad i know!
ben ive still got you're stub axle, do you need it back?
i tried to ring the guy whos making the bits before but i think hes fucked off for crimbo, tw*t......il keep on him anyways
  C63 AMG, F430 & 172
foxy, could do with in before mod jan as i have to get the car to a rolling chasis
i may have a present for you....
lol...........should i be worried?
you heading down to the meet on sunday or not? il bring it if you are, or just drop it off.....
the 4 rear stub axel bolts M10 x 150 are 57NM M8x125 are 29NM
rear calliper bolts (the two 17mm ones that hold the pad in) 60Nm
rear shock bolt (into axel) 105NM
wish bone bolts 1st, and second 90NM
the two ball joint to wishbone bolts 75NM
outer ARB bolt 15NM
subframe brace bar bolts No value is given won't matter to much just tight enough is fine.
front calliper mounting bolts (to hub) 100NM
castle nut for the driveshafts 280NM
Mounts
Top mount values The three for the engine to moun and the 4 for the mount to bodysheel are 62NM the center one holding the two bitstogether as such is 44NM
Dog bone values 62NM for all
The mount to the subframe one is 44Nm for the bolts holding the bolt to the subframe and the top one on the gearbox and 62Nm for the other bolts.
The battery mount is 62Nm for the three bolts on the engine to the mount the center nut in the battery tray is 62NM the other bolts on the body side are all 21NM
track rod end to hub 18NM for the top bolt and 37Nm for the retaining nut for the arm as such.
front and rear subframe bolts 62Nm front and 105NM at the rear
Rear hub nuts are 175NM not 300 though.
